Plexi treble pot does nothing
audiosalvage
Post by audiosalvage »
I have a 1987 20watt clone that I built last year. I put in a Merlin tube effects loop and a lar mar master volume that stays full all the time. I get a nice mid heavy, brown tone, which I like, but the treble pot seems to have no effect at all. Presence and bright caps help but no treble bite from the control. Any ideas?
Re: Plexi treble pot does nothing
Yes I have a idea, post a schematic please!
bepone
Post by bepone »
check pot wirings and value, but is funny that someone need to mention that :D
Littlewyan
Post by Littlewyan »
Is it just the treble control that has no effect? Do mid and bass work?
audiosalvage
Bass and mid pots work
syscokid
Post by syscokid »
FWIW, I recently came across something very similar with a friend’s handwired Deluxe Reverb. I found that the amp’s 250pF tonestack treble cap lost connection to the 100K slope resistor/plate terminal. In your amp’s circuit, that would be the 500pF tonestack treble cap to 33K slope resistor/cathode terminal. Or, the treble cap’s connection to the first lug of the treble pot.
Greg
audiosalvage
Ill check those, thanks
audiosalvage
Loop circuit is completely removed from the amp and still no treble control. I checked the pot and all the tonestack wiring. Stumpted
wpaulvogel
Post by wpaulvogel »
audiosalvage wrote: Sat Apr 06, 2024 9:00 pm Loop circuit is completely removed from the amp and still no treble control. I checked the pot and all the tonestack wiring. Stumpted
Post pictures please and lift the capacitor leg and check that it has the proper capacitance.
audiosalvage
I replaced the cap and it has some effect, but I guess I never realized how little the tone controls have on the shaping.
syscokid
Post by syscokid »
audiosalvage wrote: Sun Apr 07, 2024 12:07 am I replaced the cap and it has some effect, but I guess I never realized how little the tone controls have on the shaping.
Glad you posted a pic. Your tonestack treble cap looks like a 3.3K instead of a 33K.
Greg
audiosalvage
Well garsh, color me blind. That must have happened as I was trying out different slope resistors. You are a life saver, I was going to button it up and live with it. Thank you
Golden rule number 1.
Whenever working on a amp and especially a customer amp where time is money, alway double check the for the needed resistor value with your ohm meter to confirm what you think your seeing with your eyes.
Over the years I have had more then a few that had the wrong color bands in regards to what the checked out at.
