ODS Eyelet Boards
- guitardude57
Re: ODS Eyelet Boards
How much for a set of the boards?
Also, is CE still making those killer Chassis?
I'm about due to build a Robben Ford...
Thanx!
Thanx!
Mike
I am never surprised and always amazed
Probably around $90-$100 with relays. I don't think CE still makes them, but I had some similar chassis made recently.guitardude57 wrote:How much for a set of the boards?
Thanx!
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
- guitardude57
Do you have a website?
And do you still make Amp head cabinets?
I have started to make some 6V6 powered Plexi amps,
And have been looking for a cab maker also
Thanks man!
Thanks man!
Mike
New .pdf in first post includes conversion from "Classic" to "Precision" power supply by addition of 4 eyelets and 16 holes for radial filter cap leads. No, you can't change the radial caps without lifting the board, but the same is true of the PCB version.
I had these board sets made and they are for sale. PM me for details
Amplified Nation
@ampnation
@ampnation
Lay6 is sprint layout.
There is a Free viewer: http://www.abacom-online.de/updates/Spr ... Viewer.exe
- dorrisant
Martin, do you have anything made up for an HRM board?
- dorrisant
I don't mean to trouble you. I could generate a drawing and a board if I knew where the dimensions were. I have some info, probably enough to get started.
EDIT: Found it! Well, at least it will work.
https://ampgarage.com/forum/viewtopic.php?t=27261
I added a new .pdf with my take on an HRM board to the first post in this thread.
- norburybrook
this will of great help to many Martin, thank you.martin manning wrote: ↑Fri Jan 10, 2020 1:25 pm I added a new .pdf with my take on an HRM board to the first post in this thread.
I think a 250k is better than a 1M for the bass pot, the 1m is like a trigger
just my 2 cents.
M
- dorrisant
Thanks again Martin!
2 others liked this
I've added a new .pdf at the top of this thread with FET and power supply board layouts using radial caps. Axial-leaded electrolytics are getting increasingly scarce and expensive, so why not?
In addition, the relay voltage regulator is now mounted on the relay power supply board. There is no need for a heat sink as long as the current draw is limited to 150 mA in the worst case, which is where 5v relays are used with the doubler circuit and 6.3VAC input, or the FWB circuit with 12.6 VAC input. 150 mA will support three 5V relays (30 mA each) and four LED's (15 mA each), so that should not be a problem. Other combinations where the regulator drops less voltage will have more capability.
