Amp Chassis Cradle
Amp Chassis Cradle
does anyone have drawings with dimension on them for building a wooden amp cradle?
Re: Amp Chassis Cradle
See in the "chassis support" thread going on next door: http://ampgarage.com/forum/viewtopic.ph ... 676#333676
Quite a few years ago TAG had a thread on this subject.
I have the Weber cradle below.
I like this a lot. With telescoping pipes it would take up less room on the bench in use as well as when stowed.Andy Le Blanc wrote:all you need is 2 blocks of wood and some PVC
[IMG:800:600]http://i23.photobucket.com/albums/b355/bruciep07/cfa3eb23.jpg[/img]
[IMG:800:600]http://i23.photobucket.com/albums/b355/bruciep07/37ae9057.jpg[/img]
Built this a while back, expands as big or as small as I need it too, and removes completely from the bench when I need... Not wood but always good to keep your options open
Lets face it, large tube amp chassis are awkward to handle due to the
uneven weight distribution caused by heavy transformers.
So bear in mind that the base should have a wide footprint to add stability.
Kudos if you can rotate the amp while clamped in, like a rotisserie.
I'm sure I am not alone when I say I have had some close calls of almost dumping it on the floor.
YOU GUYS ROCK!! thanks for all the responses, you make a newcomer feel right at home.
I broke my Radio Shack digital soldering station working on an Ampeg SVT six 6550 PA tube behemoth.
Left over wood pieces from previous projects and maybe $10 in metal parts from Lowe's.
With respect, 10thtx
I built mine from 1 inch 80/20 material. Pretty flexible and stable.
- Jack Hester
Do you have a source online for this material? I like your cradle design. Restoring old amps makes for sometimes difficult ways of holding the chassis. Yours will work on any.JoeCon wrote:I built mine from 1 inch 80/20 material. Pretty flexible and stable.
Jack
Jack
Got mine from McMaster-Carr website. I think it's under structural framing stuff. They have short and long pieces if you have a way to cut it like a cut off saw. Also all the connectors too...
HTH...
HTH...
Wow some of those are extra cool. Would even allow to work on your amp in zero gravity
I feel like Charlie Brown, all I got is some scraps of wood. Guess it's a step up, before that I used to use a few editions of the Pittman books, Weber book and RCA/GE tube manuals.
- Jack Hester
Great! I've got an account with them. I'm headed over now. Thanks.JoeCon wrote:Jack
HTH...
Jack
