I was after a 'cleaner' amp with reverb and the PR was the form factor that seemed best. A known, classic circuit with a sound to match. But it had its flaws. So I set about updating the basic circuit (as supplied by Michael at Modulus Amplification with his Princetown kit) to include various updates people make, as well as sensible engineering updates following Merlin Blencowe's books. The original idea was to be clever and modify the existing turret board. But it was easier to just make a PCB.
All design (KiCAD 10) and fabrication files are at https://github.com/tristancollins/PrincetonReverbUpdate. The v1.0.1 release can be downloaded at this link: https://github.com/tristancollins/Princ ... v1.0.1.zip This set of files is what I have built and tested.
Things I've done:
- moved the reverb to its own node, reducing noise
- moved the LFO to its own spur, reducing thumping
- used an LED to bias the LFO, better / stronger
- added a large stopper to the PI grid, reducing blocking distortion
- reduced the PI coupling caps going to the 6V6s (I could reduce further, but we'll see), to reduce blocking
- adopted a multi-star grounding scheme using ground planes for each node, that daisy chain from the reservoir cap to the input, to reduce noise
- a single earth <-> signal ground connection near the input, reducing noise
- tried to make the off-board connections short, to make assembly easier
- it's all on one board! No need for a bias board.
This has all worked out really well, even if I do say so myself. I've got a lush sounding amp, perfect for playing in pubs and the living room, that is so quiet I can hardly tell it's on.
I've a few boards left over from the PCBway order, should anyone be interested. All you'd need is the kit from Modulus (or similar) and a few additional parts here and there. Or you can always order your own using the files linked above.
