One size fits small cabinet.
dragonbat13
Post by dragonbat13 »
Besides the fact I'm sick of hauling giant 4x12 cabs around, I live in an apartment and need to make changes.
I'm still building my marshall 2204 kit eventually. But I'm getting rid of my only 4x12 cab. I'm planning on going the "shelf with multiple heads" I see all the time.
I'm strongly considering either the Mojotone isolation cab for an extreme 700 dollars+, or an evm12l in a thiel 1x12 (the mesa type thing).
I know I won't get the full half stack effect, but I need something small.
What's the opinion of those two, and should I consider anything else? Fenders, Marshalls and dumble clones are the amp styles.
Thanks.
Mark Clay
Amature/Hobbyist/Electronics Hoarder
GAStan
Re: One size fits small cabinet.
Post by GAStan »
I cannot give you a comparative opinion as I do not have a Mojotone cabinet but I do have two Thiele TS806 1x12 cabinets, one with EVM12L and one with the WGS equivalent.
They sound much larger than they actually are. With a Dumble style on a clean channel they are very clear with plenty of low end. Also very unforgiving, not necessarily a bad thing as they will make a player improve their technique. Kick in the overdrive and the amp's distortion is heard, very little if any speaker breakup even with a 100 watt amp cranked. IMHO having the two 1x12 is much more versatile than a single 2x12, especially if one has multiple amps where you can experiment with stereo effects with good speaker seperation.
I will add these speakers are very bright when brand new but warm up considerably as they break in. Personally I didn't care for them initially but now I REALLY like them.
My speakers were made by TRM Cabinets. Tim will make the cabinet wider with an interior wall to maintain the proper internal volume if you ask him to. My Thiele cabinets match the width of my Dumble ODS style amps perfectly.
Glenn
I solder better than I play.
solderhead
Post by solderhead »
dragonbat13 wrote: ↑Sat Apr 12, 2025 9:16 pm ...
The EV TL Series and the Iso cab are designed to cover two opposite extremes of sound reproduction. Which one do you want? the EVM/TL Series systems are intended to maintain 'distortion-free' sound reproduction with large signal levels (much higher than you could ever reach reasonably in an apartment setting). OTOH an iso box is purposefully designed to allow you to cultivate large signal speaker distortion in a confined space and mic it for reamplification. I'm not sure which objective you're after.
Do you want speaker distortion as part of your sound or not? You'll get it with the iso cab but you won't get it with the EVM/TL Series systems like you would with Celestions. As far as the size constraints go, an EVM/TL combination is nice and compact, while an ISO cab and a reamplification system are going to take up a lot more space. It's not clear what your goals are. I understand the need to reduce footprint, but your sonic goals aren't quite clear to me.
Better tone through mathematics.
solderhead
Uh-oh -- the prospect of using a TL Series cabinet with a speaker not designed for it is going to lead me into a long Sunday rant. I apologize in advance, this post will be long.
TLDR: Swapping speakers into T/S cabinets that don't match their T/S parameters is a bad idea. Blown speakers may result.
GAStan wrote: ↑Sun Apr 13, 2025 12:30 pm I cannot give you a comparative opinion as I do not have a Mojotone cabinet but I do have two Thiele TS806 1x12 cabinets, one with EVM12L and one with the WGS equivalent.
I heartily agree with all of the comments in your post -- the EVM-12L/TL-806 is compact, loud, clean and bassy without being boomy in an almost enigmatic sort of way. For people who are used to a 4x12 it seems odd that such incredible bass response could come out of such a small enclosure. I'd have no reservations about getting rid of large cab like a 4x12 and replacing it with an EVM driver in a properly matched T/S cabinet design. That's exactly what I did when I was renting apartments.
I'd be cautious, though, about speaker substitutions in a TL-806, which is why I quoted part of your post. Driver substitution in a T/S cab is a very BAD idea. Back in the day ('70s-'80s) everyone in pro audio knew that you couldn't take a T/S array and drop in an unmatched driver that the enclosure wasn't specifically designed to support, as that typically resulted in either poor performance or destruction of the driver. The idea of speaker swaps became popular among those musicians without an audio engineering background because someone at Mesa decided that it was a good idea to put Celestions in the TL Series cabinets (whose design came from EV) after EV had exited the musical instrument speaker market and left Mesa without speakers to put in their EV-designed cabinets.
IMO this decision for the Mesa speaker swap was made, not because the Celestion drivers were a good match for the EV cabinets, but because Mesa had EV-designed cabinets with no EV drivers to put in them and an ample supply of Celestions. So Mesa just stuffed the EV designed cabs with Celestions and pulled the wool over everyone's eyes by calling the new speaker used in the T/S cabinet a "Celestion Black Shadow" instead of an "EV Black Shadow," thereby implying that there was some degree of equivalence between the Celestion and EV speakers. (!) IMO that bad idea has become so widely accepted now that there is a cottage industry of enclosure builders who will gladly sell you a cab that's built to TL-806 plans without having any clue that the design is ill-advised for use with non-EV speakers, or that the cabinet design should be changed to suit the T/S parameters of the speaker to be installed in it. Today the guitar cabinet market proceeds with speaker swaps in a willy-nilly fashion, with the result that nobody understands what actually happened when they blow up speakers.
I blame Mesa for the propagation of this nonsense belief that it's safe to swap speakers willy-nilly into T/S ported cabinets. Mesa had relied upon EV engineers to design their T/S speaker/cabinets and didn't know what to do after EV decided to exit the industry. From an engineering standpoint it looked like Mesa had no clue as to what a bad decision they had made. [I'll leave it to the reader to determine whether Mesa was ignorant of the problem or whether Mesa purposefully used it as a means of selling replacement V30 on their web site.]
Why is this a big deal? In the T/S cabinets the box volume (air compliance) and the port dimensions are precisely tuned to the T/S parameters of the driver. The system will not function properly if a driver is used whose T/S parameters don't precisely match the design of the cabinet. When improper substitution takes place one of two things is likely to happen: the speaker will not develop the proper bass response due to misalignment of the driver and the cabinet, or the speaker will self-destruct when large signals are applied due to that same misalignment.
IMO Mesa did a great disservice to their customers by obfuscating the difference beween the EV and Celestion speakers by giving both the name "Black Shadow" and by placing Celestions into a T/S cabinet that was specifically desgined for EV speakers. At the time that Mesa did this Celestion refused to even publish T/S parameters for their speakers. In other words, it just wasn't possible to do the math to confirm that the speaker swap was safe because the new driver's characteristics were not published. Apparently, nobody at Mesa was worried about Thiele-Small math, or more importantly, Margolis-Small math. The result of this was good for Mesa, as they were spared the expense of redesigning a new T/S cabinet, and they ended selling a lot of replacement V30 speakers as the drivers blew-up.
Why does this happen? The primary design objective of a T/S cabinet is to extend bass response by tuning the volume of air in the cabinet, it's compliance, the dimensions of the enclosure's port, and the compliance characteristics of the driver to create a resonant system.
To put this into perspective it's important to understand that the TL-806 was never designed to be a guitar enclosure. It was designed for midband PA use, with an intended bandwidth of 83-1600 Hz.
In a T/S design the port (vent) produces the lowest octave of bass response. The tuning of the driver/port/air in the cabinet (and a bit of electronic EQ boost) define the usable lower limit frequency of the cabinet (fLL). They allow the vent to be driven to it's full acoustic output by the air in the enclosure moving through the port, rather than linear displacement of the driver along it's axis of excursion, to move air to produce sound. When reproducing the lowest tuned frequencies for the T/S cabinet, the amount of driver displacement (X) is actually very small -- the driver does not have to move very much to excite a large volume of air in the tuned system. The excursion of the driver at frequencies where the port is active is very small relative to sealed or open-back enclosures. This allows the harmonic distortion of the system to be markedly reduced in the ported cabinet and significantly reduces the chance of speaker bottom-out... that is, until you drive the T/S array with program material that exceeds fLL for the array, or drop in a driver that does not have the T/S parameters required by the cabinet.
The TL Series cabinets were not originally designed for guitar. They were designed for tri-amped or quad-amped PA use with the intent that they would be used in conjunction with the EV XEQ-1/2/3 crossover/equalizer, in order to provide a small degree of bass boost to provide flat bass response down to a defined f3 point AND to provide a high-pass filter with 12-dB-per-octave slope slope below the peak-boost frequency designed for the specific TL Series enclosure, to protect the driver by removing subsonic energy below the lowest usable cab frequency. It is an unfortunate reality that when the TL Series cabs are used for guitar applications the XEQ-1 is not used and the speaker is not afforded the protection against low-frequency over-excursion that the EQ system was designed to provide. In guitar applications, the TL Series cabinets are typically run naked, with no EQ boost to flatten their response and no crossover protection to prevent over-excursion below fLL. That creates a serious problem.
At fLL the driver performs at an operating point where the driver/cab/port/internal air are tuned such that the driver experiences almost insignificant displacement as it is the volume of air in the cabinet and the port that produce sonic output. If/when fLL is exceeded the tuning of the port is exceeded and speaker displacement becomes required to move air to produce sound. The problem is that the necessary driver displacement increases logarithmically the farther the port frequency is exceeded in the low direction, until the driver's maximum permissible displacement (Xmax) is exceeded. For an EVM-12L Xmax is only 0.13". The XEQ was mandated to protect the driver from over-excursion, as over-excursion rapidly kills drivers. Unfortunately nobody uses proper EQ when deploying the TL Series cabs for guitar use,with the result that there is no protection against this failure mode and blown speakers commonly result.
FWIW I have been using EV/TL series cabinets since the 1970s, properly protected by an XEQ-2 in a rack system with obscenely high power amps and I have never blown a speaker. Knock on wood.
If anyone is interested in using the TL Series cabs, I would recommend using them only with drivers that they have confirmed to be compliant with the T/S specs for the specific TL Series cabinet, and preferably with a proper 12dB/oct protection crossover so that Xmax is never exceeded. If those precautions are taken then it is unlikely that the driver will ever fail, short of several hundred watts of thermal abuse.
The TL-806 was designed for two EVM drivers: EVM-12L or -12S. I would use caution in using a TL-806 cabinet with any driver when used with a de-tuned guitar without adequate LF protection. If the frequencies being reproduced by a de-tuned guitar exceed the cabinet's port tuning frequency in the low direction then driver destruction is a likely outcome when subjected to large signals. I only use the EVM-12L + TL-806 combination with a normally-tuned guitar. For any de-tuning (or for 4-string bass), I use the EVM-15L + TL606 combination. I've been using the 12L/806 and 15L/606 combinations since the 1970s and I've never blown a speaker with guitar or bass and amps as large as a 300W SVT and kilowatt PA amps. When deployed properly the EV TL Series cabs are quite robust.
captaincoconut
Post by captaincoconut »
GAStan wrote: ↑Sun Apr 13, 2025 12:30 pmI cannot give you a comparative opinion as I do not have a Mojotone cabinet but I do have two Thiele TS806 1x12 cabinets, one with EVM12L and one with the WGS equivalent.
Sorry for going a bit off-topic here but how do you feel about the WGS 12L compared to the original EVM? I'd like to equip a 4x12 with EV type speakers for my Steel String Singer build but don't see myself spending the dollar for new EV speakers. The WGS equivalents seem like a reasonable alternative.
GAStan
Post by GAStan »
captaincoconut wrote: ↑Mon Apr 14, 2025 7:14 am Sorry for going a bit off-topic here but how do you feel about the WGS 12L compared to the original EVM? I'd like to equip a 4x12 with EV type speakers for my Steel String Singer build but don't see myself spending the dollar for new EV speakers. The WGS equivalents seem like a reasonable alternative.
Its close but I do slightly prefer the EVM over the WGS. If money were the determining factor i wouldn't hesitate with another WGS. I did buy the two different brands to answer the very question you ask. Currently the WGS is on loan with a 100 watt amp I made to a gigging musician that practices pretty much daily and gigs it 1-4 times a month. I haven't heard it since it's loaned it but need to as it wasn't quite broken in when he picked it up.
To Solderhead, I agree with much of what you said. Actually everything. I thank you for the lengthy and very educational response. If i were building a HiFi or even a P.A. I would most definitely select the appropriate EVM. However the WGS is a good clone of the EVM. I didn't do the math because the parameters available seem close enough that the enclosure works well enough for a guitar speaker. The power rating of the speaker, 200 watts, vs the amps power output, 100 watts, or 3dB, provides enough of a safety net that I have no fear of speaker damage. Net result as you pointed out is lack of accurate fidelity which is quite common in guitar use. Whether this particular lack of fidelity is desirable is, I'm sure, a topic that could be widely debated.
On a side note, when you describe a speaker as "blown up" i envision a cone now consisting of confetti and frame of mangled shrapnel. :D
Glenn
dragonbat13
solderhead wrote: ↑Sun Apr 13, 2025 11:14 pm
Well. I did leave a few details out. I have a recording setup. The iso cab could be used to record in an isolated setting.
I'm not shooting for speaker breakup. I won't be able to crank anything up to power amp distortion/speaker breakup right now.
I have considered an attenuator for lower volumes. I've never tried one.
I have wanted an thiel cab for the longest time. I'm looking for the described, clear accurate sound without speaker breakup. My amp nation 2x12 gets more clean playing through it than anything.
I'm probably just going to build the thiel and see how I like it.
Thanks for the info.
Mark Clay
solderhead
If you're going to build your own cab then it'd be worth downloading one of the T/S enclosure design spreadsheets and running the numbers for the driver that you plan to use. You might find that you need to make changes to the cab size or the port dimensions if you plan to use a driver that's not the one that the cab plans were designed for. I looked up the T/S params for the Warehouse 12L and the EVM-12L and the T/S parameters are not the same. I did not run the numbers on a cabinet design spreadsheet to determine how much the differences should change the enclosure's design, though when eyeballing them some of the numbers did seem different enough that I would want to run the calculations if I were considering a driver substitution .
IMO attenuators are very helpful for dialing an amp into "the zone" when volume levels are still high. they change the tone a lot if you're going for whisper quiet levels. For bedroom type levels I've always found that an amp that's designed to do it's tone shaping in the preamp can work very well if it has a good master volume.
You say that you've got recording gear -- have you ever tried a loadbox and reamping?
