SS Cathodyne PCB - LND150
Design and discussion around PCB Design that doens't suck!
tristanc
Post by tristanc »
Was thinking of upgrading my FireFly to be a 'proper' push-pull instead of self-split. Rather than adding another tube or touching the preamp I'll simply add a basic solid state cathodyne splitter using an LND150. This looks good in LTSPICE and increases the clean power output over self-split a bit.
Anyone see any issues?
tristanc
Re: SS Cathodyne PCB - LND150
Post by tristanc »
I've updated the schematic a bit - added the ability to apply from NFB from OT to grid and added a cathode bypass cap - seemed to make the frequency response between the two outputs more symmetrical. These ideas borrowed from the Marshall 1 Watt JTM.
I'm getting a couple of boards made up and if they work I'll put the source files on my GitHub https://github.com/tristancollins/amps
stephenl
Post by stephenl »
I played around with a source-o-dyne feeding a pair of KT66's a while back, it behaved well and was transparent. This is the implementation I used. Probably should have G>S protection diodes and a gate stopper...
Steve
tristanc
Post by tristanc »
Thanks Stephen - good to hear a positive outcome. And also referring to it as a source-o-dyne - might have found more hits if I'd searched on that.
I think you have the output caps drawn the wrong side of the 22k resistors? But I get your point! Fixed bias too - had thought of that but copied from the 1W Marshall design. Will update once I have the board up and running.
stephenl
Post by stephenl »
Hah, yep, caps in wrong place. I scribbled it up quickly to stick in the post
Steve
tristanc
Post by tristanc »
In my haste to get a board made I forgot about the problems with using FETs and self bias... So I've modified my PCB to be fixed bias. I can easily modify the boards I have had made (cut a trace plus a couple of jumpers) so no real issue. Will report back when I have it working.
https://github.com/tristancollins/amps/ ... -Cathodyne
stephenl
Post by stephenl »
Cool, looking forward to hearing how this works out
Steve
stephenl
Post by stephenl »
Did you ever get a chance to play around with this?
Steve
tristanc
Post by tristanc »
I've populated the board, made the change to fixed bias (cut a trace and needing a jumper from memory) and I'm now just waiting for a free afternoon to get it in to the build. Ideally I want to take some measurements of max clean output and max overall output before and after the installation. I should get a bit of a bump according to LTSpice. Will report back.
Tristan
tristanc
Post by tristanc »
stephenl wrote: Wed Jul 15, 2020 1:22 pm Did you ever get a chance to play around with this?
OK, so finally got this installed, and it passes sound. But I think there's an issue. The attached shot of the scope shows what's happening:
Light blue is amplifier input (200mV)
Pink is speaker output
Dark blue & Yellow (inverted) are the outputs of the cathodyne/souce-o-dyne.
Why would the outputs of the cathodyne sharp clip at ~1.5V? What I hear is, even with the MV on full and gain on very low, I'm getting slight break-up when I'd expect it to remain clean.
I'll go back in today with a scope and take readings at the input to the cathodyne and the two outputs.
Schematic looks fine. What voltages do you have for supply, drain, and source, and the junction of the 1M5 and 470k? What's the input signal level?
tristanc
Post by tristanc »
Thanks Martin - found the issue. Would help if I had applied a bias voltage to the LND150 gate... Forgot an all important jumper. All working as it should.
Some readings:
Clean out sine wave: 2.8Vpp (0.11W) with self-split, ~4Vpp (0.25W) with source-o-dyne into 8ohm load
Max out square-ish wave: 7Vpp (1.5W), 9.6Vpp (2.88W)
So in line with what I had expected from simulation. The amp itself sounds much like it did before, which is also a good result.
stephenl
Post by stephenl »
What were your HT, G,S,D, bias voltages?
Steve
tristanc
Post by tristanc »
stephenl wrote: Mon Jul 27, 2020 6:34 pm What were your HT, G,S,D, bias voltages?
I didn't make a note I'm afraid.
I was in a bit of a rush, so wired it up, checked continuity etc, turned on and scoped it. Spotted the issue and verified with a quick play-through. Of course, in my haste I left off a jumper to apply the HT to the 'top' of the voltage divider for the bias voltage. Less haste more speed etc.
I'll go back in soon and take some readings - although it's pretty tight in there to get a probe in! HT should be ~265V.
