Parallel triodes
cdemike
Re: Parallel triodes
Post by cdemike »
Jiyahana wrote: Sat Jan 27, 2024 10:51 am The active triode sees the actual values of the resistors such as 110k Rp and 1.5k Rk when using only one input in a setup with parallel triodes and the grid of the inactive triode is grounded.
Not completely accurate: As Martin pointed out earlier:
martin manning wrote: Mon Jan 08, 2024 6:25 pm The triode with the grounded grid won't be inactive. Its Vg and Vk are fixed, but it's plate current will vary with the fluctuating plate voltage, and it will be out of phase with the other one, which will cancel some of the output signal.
It's easy to see the effects in a LTSpice simulation. You can also compare the results with equivalent gain stages using these:
https://www.ampbooks.com/mobile/amplifi ... ive-mixer/
https://www.ampbooks.com/mobile/amplifi ... impedance/
Something seems odd in this user's posts. May be a bot.
Colossal
Post by Colossal »
The bot won't be coming down for an Ampgarage breakfast.
ViperDoc
Post by ViperDoc »
Bot whiff is a thing? You guys are good.
Just plug it in, man.
dorrisant
Post by dorrisant »
... looks around for any evidence of something that once existed. This was not possible, since if anything was left at all, it was just a vapor. A vapor that was only noticable if looked for.
Haha. I guess I missed it. :shock:
