Would you have bet money that you did? ;^)
SSS #002 REDRAW DRAFT
Re: SSS #002 REDRAW DRAFT
Would I have won?
Glenn
I solder better than I play.
You are correct. It took me reading it several times to catch on-if I did. The "Did I get it correct?" was actually meant for Ryan
Glenn
oh!! That is much clearer.. Thanks, Martin! I apologize if I missed any communication about this discrepancy before. Looks like I'll need to try it in my amp and possibly update the layoutmartin manning wrote: ↑Mon Apr 22, 2024 5:48 pm Hi Ryan, it's this. As drawn vs. the red. Your layout shows the red.
Ryan
https://www.thetonegeek.com/
No problem, and it basically reduces the output 1 dB if the feedback goes direct to the grid. Other than that, I don't know.
Thanks, Martin! Always a cordial interaction with you that I continue to appreciate!martin manning wrote: ↑Mon Apr 22, 2024 8:29 pm No problem, and it basically reduces the output 1 dB if the feedback goes direct to the grid. Other than that, I don't know.
I updated the layout with this correction. Fun fact: I looked through my pictures and I had this arranged correctly at first and somewhere along the line I changed it to the incorrect way. Oh well. I'm glad it's proper again!
Ryan
Just noticing this traffic. Is my "redraw" draft correct, then, with respect to the Reverb input NFB? It looks like it is to me. Best.
Just plug it in, man.
Yes, yours matches the hand-drawn schematic.
