ODS Eyelet Boards
Re:SSS Bipolar Supply Updated
SSS Bipolar supply board has been updated to include a current limiting resistor at the bias tap input, and a balance/bleeder resistor across the positive output.
The 33 ohm AC input resistor reduces the peak charging current pulses by about half, and reduces the RMS current drawn from the PT by about 30%. As far as I know, no one has lost a transformer using this driver supply circuit, but it seems worth the effort to add this feature, and it may help reduce noise. The output voltage drops a few volts on each side, but there is still more than enough for the circuit to operate. The complete adjustable bias supply network is also shown, with values adjusted to recover the original design bias voltage, and reduce the current draw slightly.
The 330k resistor across the positive side partially balances the current draw from the bias circuit, and also acts as a bleeder. It could be located anywhere, but it"s convenient to place it across the output eyelets on this board.
Re: SSS Bipolar Supply Update
The SSS bipolar driver supply board in the first post has been updated again with some fine tuning. The bleeder resistor mentioned above has been reduced to 150k to balance the current draw on the positive and negative sides, and to allow the voltages on both sides to drain in about a minute after shut-down. The AC input current limiting resistor has been increased to 47 ohms, with the result being the RMS current is still about 30 mA. The resulting loss of a couple of volts DC will not be noticed. The text in the first post and in the .pdf have also been edited for clarity.
