2nd gen chassis and pcb design?
2nd gen chassis and pcb creation; good idea?
Poll ended at Thu Aug 17, 2023 6:52 pm
Yes both chassis and pcb.
11
58%
Yes, but only chassis.
4
21%
No, Im loaded
2
11%
No, no interest.
2
11%
Total votes: 19
erwin_ve
Re: 2nd gen chassis and pcb design?
Post by erwin_ve »
dbharris wrote: Thu Aug 10, 2023 2:55 pm Excited for this. Thank you for taking the time and effort on this project!
-Dan
Thanks Dan!
After the chassis are cut, bend and welded they go for powdercoating, after that procedure they go for silkscreen.
Pcb are ready next week.
Erwin
erwin_ve
Post by erwin_ve »
Pcb are ready!
The main board is coming with a insulator board as seen in other ODS amps.
Cool project you have going on. Great to see all these options for builders.
erwin_ve
Post by erwin_ve »
I got the chassis from the metal shop. They did a nice job!
Next week they will be powdercoated.
erwin_ve
Post by erwin_ve »
The chassis are powdercoated!
Friday they are going for screenprint.
When powdercoated the groundpoints are covered:
After the coating is applied and dry baked the covers are removed.
dbharris
Post by dbharris »
Looks great!
erwin_ve
Post by erwin_ve »
The chassis are ready and look great with screenprint.
I started populating a pcb set for a proof of concept build.
erwin_ve
Post by erwin_ve »
Put them in the sale section!
erwin_ve
Post by erwin_ve »
Some progress on the proof build.
erwin_ve
Post by erwin_ve »
More progress.
The wire used in my previous builds was running out and for this one I used Alpha wire solid core 18awg, 1kV, pvc.
That wire supposed to be be tinned copper, however this is not as soft copper as I was used too.
Anyone got experience with this specific type?
Guy77
Post by Guy77 »
erwin_ve wrote: Sun Oct 15, 2023 2:29 pm More progress.
Great looking build Erwin!
I used the Alpha solid core 18AWG in a build once and it was hard on the hands. Took longer to work with too. I went back to using this wire in the preamp:
https://www.cedist.com/products/wire-we ... 0v-50-feet
and this in the power amp:
https://www.mojotone.com/20-Ga-Pre-Tinn ... oated-Wire
Sometimes I will use the same 20AWG in the preamp too. The stranded coated wire is quick and easy to work with.
Cheers
Guy
VolkerStaub
Post by VolkerStaub »
Hey Erwin,
fantastic work again from you for the community! Bug ups for that!
Is there a specific reason why the frontpanel of the cassis has no "OVERDIVE SPECIAL" labeling just like on the SSS chassis you sell?
Looks kinda odd with that big blank space in there.
erwin_ve
Post by erwin_ve »
Guy77 wrote: Mon Oct 16, 2023 1:14 pm
Cheers
Guy
Thnx Guy, yes probably better to use 20awg anything but heater wires. I had such a big stash of wire over the years, I completely forgot the exact diameters to order.
Plenty of 18awg now.
Erwin
erwin_ve
Post by erwin_ve »
VolkerStaub wrote: Mon Oct 16, 2023 4:36 pm Hey Erwin,
Thnx VolkerStaub,
Steel String Singer has a nice spacing on that spot.
Overdrive Special without a builders name doesn't look right as far as esthetics.
From what I gather buyers generally want it blank on that spot to put something on themselves.
Easy to do in black with all print options these days.
Charlie Wilson
Post by Charlie Wilson »
And then there is the trademark thing.
CW
