NEW RUN 2023 ODS Chassis and Board sets available[ EU ]
- erwin_ve
Overdrive Special chassis and pcb boards for sale.
Chassis 2mm CNC lasercut, 5745 H111 aluminium with inserts for cage nuts.
Chassis is black powdercoated and silkscreened with white lettering.
Pcb boards: All boards are 1,6mm thick with 1 oz copper, one exception; the Ps filter board is 2mm thick with 2 oz copper. 65 Euro excl shipping for a set.
If you want only relay pcb; they are 4 euro each.
A set is;
1 Rectifier/Bias board with insulator board.
1 Rectifier/filter board for relay with insulator board
1 PS filter board.
1 signal board
1 Fet board with insulator.
2 relay boards with insulator boards.
€150 for the chassis excl. shipping.
€65 for the pcb set excl. shipping.
€210 for chassis and pcb package excl. shipping.
Questions? PM, I try to react asap!
Erwin
A set is;
1 PS filter board.
1 signal board
Erwin
Re: New run 2021 ODS chassis and board sets available[ EU ]
PCB pics:
Thanks Martin. yes I use the same mounting centers as in your eyelet version(CE chassis), boards may differ slightly in outer dimensions as I use mm as a base, but no more than 1 mm. Mounting is as per "original".martin manning wrote: ↑Thu Sep 02, 2021 12:49 pmLooks great! What are your board dimensions and mounting centers? Same as the "standard?"
Re: NEW RUN 2021 ODS Chassis and Board sets available[ EU ]
Bump. Are these still available?
Cheers.
Cheers.
Yes, these are available, I have an order en route
- erwin_ve
5 sets available!
3 sets available.
Hi I might take all three boards and chassis. How confident are you your PCB boards will sound as good as eyelet hand wired? I note that your Dumble SSS has Dumble Logo... he left the planet there is still an issue putting that on an ODS. If you can give me an idea of the dimensions of a box of 3 and teh weight I'll get a friendt quote on my DHL account. I can wire transfer EUR to you PM me if you can do us a deal on all three please? Cheers.
- erwin_ve
Hi Kanga,Kanga wrote: ↑Sun May 08, 2022 8:38 pm Hi I might take all three boards and chassis. How confident are you your PCB boards will sound as good as eyelet hand wired? I note that your Dumble SSS has Dumble Logo... he left the planet there is still an issue putting that on an ODS. If you can give me an idea of the dimensions of a box of 3 and teh weight I'll get a friendt quote on my DHL account. I can wire transfer EUR to you PM me if you can do us a deal on all three please? Cheers.
The pcb boards are very close to a real Dumble, the main signal board is based on the eyelet version posted in the files section. I made the through holes as close as possible to a eyelet. In my experience it can sound as good as a Dumble, so it depends on the skill of the builder.
My SSS doesn't have a Dumble logo, I'm not sure what makes you think it does?
For shipping details pls PM me with adress, country so I can give a estimate.
Erwin
Bump, still available!
Still available, also the HRM boards are available again for the HRM and Bluesmaster builds.
Re: NEW RUN 2022 ODS Chassis and Board sets available[ EU ]
5 sets( 3 pre amp tube holes + pcb set) available and 5 chassis available with 4 pre amp tubes holes.
