Beginning my Liverpool build!
- Ledvedder5150
Here the arrival of all the parts for my Liverpool build. After seeing Pete Thorn's video, I knew I had to build one. I got all the parts from Michael at Modulus Amplification. I've done a few of his amps previously, so I trust his judgment. F&T and Orange Drop caps were supplied. Looking forward to this one for sure! If anyone has any opinions, recommendations, criticisms, I'm welcome to it all. I realize there's a special mystique around these amps, so I'm hoping to capture a bit of that magic with this build.
https://photos.app.goo.gl/cnNpHhxBptD2dANZ7
Re: Beginning my Liverpool build!
I hate to say it but having the output transformer that close to the preamp tubes may create problems.
- Ledvedder5150
Yeah I hear that. I've contacted Modulus to ask if it's the correct way to mount it.wpaulvogel wrote: ↑Thu Jan 05, 2023 3:17 am I hate to say it but having the output transformer that close to the preamp tubes may create problems.
- Ledvedder5150
This is how the Rocket clone pictured on Modulus' website. He doesn't have a Liverpool kit pictured currently. He customized this kit for me. Mine doesn't have a rectifier tube, and will have a presence pot. Does the positioning of the OT here make more sense?
- Ledvedder5150
The PI tube is way less sensitive to noise injection. It's running at much higher current and voltage by then and so likely not an issue...
- Ledvedder5150
I did the "headphone trick" to determine the best placement for the OT. I gotta say, Modulus' recommended placement is spot on. It produced the least amount of hum of anywhere on the chassis.
Don't count your chickens before they hatch. Just wait 'til you wire up those preamp tubes!Ledvedder5150 wrote: ↑Sat Jan 07, 2023 2:51 am I did the "headphone trick" to determine the best placement for the OT. I gotta say, Modulus' recommended placement is spot on. It produced the least amount of hum of anywhere on the chassis. 20230103_205840.jpg
- Ledvedder5150
No worries. I'll leave long enough leads if it's an issue after the build is done.sluckey wrote: ↑Sat Jan 07, 2023 2:55 amDon't count your chickens before they hatch. Just wait 'til you wire up those preamp tubes!Ledvedder5150 wrote: ↑Sat Jan 07, 2023 2:51 am I did the "headphone trick" to determine the best placement for the OT. I gotta say, Modulus' recommended placement is spot on. It produced the least amount of hum of anywhere on the chassis. 20230103_205840.jpg
The revised/unusual placement for the OT is surprising, to say the least. Trainwreck(s) are extremely optimised amps, according to the legend. There seems to be very little margin for modifications, beyond using cap cans to avoid the stack thing, does it seem ...
NOOOOOOO!!!
My Liverpool sounds EXACTLY LIKE CHANTE and circuit is confirmed identical and the transformers are IN THE TYPICAL PLACES.
The transformer belongs -----> over here. Put it over here ----->
- Ledvedder5150
I'm still contemplating moving the OT. But until then, I've been slowly doing some work on it.
- Ledvedder5150
Even though I got some significant hum over there?Reeltarded wrote: ↑Tue Jan 10, 2023 12:14 am NOOOOOOO!!!
The input is supposed to be sensitive up to the edge of unstable on these amps, according to what I could read here. Therefore, the hum may well be a minor problem when the build will be finished, or you'll be forced to tame the input and risk loosing that "trick".
How about you keep mounting the amp but being prepared to move the OT latter on, so not much trouble so far?
Great project, by the way!
