Komet K60 or Concord Layout
Re: Komet K60 or Concord Layout
Post by Mark »
I have put off buying a Larry Mann cab for my Rocket amp. The idea was to wait till I built my Express but I don't have a need for an amp that loud. I have thought of running it with 6V6's but it will still be loud.
Tell me about your Larry Mann cabs?
flying_high
Post by flying_high »
I agree with you, I can't handle loud amps without master volumes.
My Larry Mann cabs:
Komet 60
Concorde
Express (middle cabinet)
Colossal
Post by Colossal »
I drool every time I see those, Mark. I've had two of Larry's cabs and they are beautiful. The man does killer work.
Post by Mark »
All the cabs look great, in fact the middle cab looks sensational. Thanks Mark.
Colossal
Post by Colossal »
Mark,
Here is one of Larry's. Not a great photo but you can see the insane chatoyance.
Post by Mark »
Agreed it's quite beautiful, though I had a Homer Simpson moment: Chatoyance is an optical phenomenon in which a band of reflected light, known as a "cat's-eye," moves just beneath the surface of a cabochon-cut gemstone. Chrysoberyl and tiger's-eye are two of the best-known gem materials that exhibit this phenomenon.
I really like your cabs Dave to bad you sold those amps/cabs.
Here is another shot of my Express cab.
Post by Mark »
Does Larry put info the plate such as volume bass treble etc as well the animal picture between the controls and the on/off and standby switches?
How do you do the nuts on the pots tight enough without crushing the wood on the front panel yet getting a good solid earth connection?
Colossal
Post by Colossal »
Mark wrote: Wed Dec 27, 2017 11:57 pm Does Larry put info the plate such as volume bass treble etc as well the animal picture between the controls and the on/off and standby switches?
Yes, he had my faceplates laser engraved.
You can tighten them down. But for me, I do not rely on the pots for ground. I used a preamp ground bus bar and tie that to the input jack. The power amp (capacitor) grounds are tied to the chassis per the usual Trainwreck format.
Winder
Post by Winder »
Beautiful cabs. Wow.
Post by Mark »
Thanks for your advice Colossal. :D
I use CTS for Mojotone pots they are 3/8" diameter, threads are 3/8" long to go through chassis and faceplate without worrying about threads and I do like Colossal does separate ground wires or run a buss wire not soldered to the pots.
norska
Post by norska »
Hey guys, Is it possible to change a K60 into a K50? If so, What all has to be done? I'd like to have an amp tech do it for me. I live in Portland OR BTW- Can anyone recommend a tech for this job? Thanks!!
Post by Mark »
Have a search about this forum for info on the differences between an F60 and F50.
http://ampgarage.com/forum/viewtopic.ph ... F50#p35758
This article has photos too.
