JTM 45 OT Impedance
JTM 45 OT Impedance
I've looked around some and the general consensus seems to be using 8k historically, while 6.6k will yield a cleaner, more low end response with 5881s and KT66s. Correct me if I'm wrong because I know there was some mismatching going on. I have the RS triple primary including 3.4k. I don't plan on running EL34s because I don't think I will go for that sound, but 5881s and KT66s are a definitive yes. The secondary is at 8 ohms only so I won't be doing any mismatching with a cabinet.
Just curious as to everyone's opinions for which one may be preferred over another for different reasons.
David
David
Re: JTM 45 OT Impedance
Exactly as you say. The 8k will be less linear, and the 6k6 will be notably cleaner sounding with more of the lowend that you'd get with a fenderish amp. some say too much. I wonder what the hell they are hearing.
Okay cool. I'll go with 8k then. I plan on using a 220uf cathode cap on v1 and don't want an overflow of lows, especially since I play a LP. I'll definately try out the 6.6k just to experiment, but who knows, maybe that's what I'll dig with my LP. I did read that Clapton's BB Marshall was wired for 6.6k.
David
David
- LeftyStrat
Don't shy away from at least trying the 3.4k with EL34's. That turned out to be my favorite with my jtm45, at least for a strat.
Yeah I may do that when I (eventually) buy some XF2s. I just always think of them with SS rectification and hotter pres. I guess I could always pop in the diode cap in the rect socket and make a .68 cap switchable on v1s cathode, with a bias adjustment of course, and then see how she do...
Actually that sounds pretty cool.
David
David
- LeftyStrat
One of my favorite production amps is the Germino Club 40. I modded my JTM45 to similar specs. I used a tube rectifier, dropped the first cathode bypass cap to 5uf. Increased the preamp filtering to 32uf.
I just found the original JTM45 to be very woofy, undefined bass. I didn't want to go all the way to fifty watt specs. Just wanted something in-between.
Just keep in mind, my mods were for great strat sounds. It definitely takes it further away from the Beano tone.
Here's my favorite clip of the Club 40:
http://www.germinoamps.com/audio/tribute.mp3
Some clips with a Les Paul:
http://www.germinoamps.com/audio/club40/c40_ledzep.mp3
I always TRY to plan for the easiest form of awesome. I have a theory about simplicity and available parts so I not only like the 34s for the sound, they are endearing in their ubiquity. Even maw and paw have a pair of 34s over at ye locale music shoppe. KT66 not suh'much!
I also believe the tone is in the player. Your fingers know how to make your amp sound not so dirty.
Anything that a diode bridge or a tube choice will do can be tweaked around as well. I have made some wildly clean leaning Marshalls in the last couple years. I like SS rec because it costs twelve cents and it isn't likely to flash itself to death after moving AND it sounds good. heh
Oops! Wrong thread!
Oops! Wrong thread!
- LeftyStrat
I guess my problem is a strat into a JTM-45 with KT66's didn't have enough dirt. I guess my fingers aren't big enoughReeltarded wrote: Your fingers know how to make your amp sound not so dirty.
I will admit when I was messing with the JTM-45 circuit, the only production KT-66's at the time were chinese.
The other variable is I used a PT I bought from Paul Ruby that I think might have been too good or over-engineered for the circuit.
Sometimes bad is good.
At least that's what I keep telling the ladies.
The 65' that I worked on had the RS OT wired for 8K and had almost 460V on the plates. So when I built my clone a few years ago, I used an 8K and it has 450V on the plates. Personally, for a straight JTM45 I prefer the higher voltage and the 8K tap. The 6.6K version and low plate voltage can get a bit muddy.Blackburn wrote:I've looked around some and the general consensus seems to be using 8k historically, while 6.6k will yield a cleaner, more low end response with 5881s and KT66s. Correct me if I'm wrong because I know there was some mismatching going on. I have the RS triple primary including 3.4k. I don't plan on running EL34s because I don't think I will go for that sound, but 5881s and KT66s are a definitive yes. The secondary is at 8 ohms only so I won't be doing any mismatching with a cabinet.
David
I like the JTM50(el34/3,4K version) with the softer voltages in the 415-420V range.
TM
I don't think anyone knows for sure, as I've read that it was wired for 9K.Blackburn wrote: I did read that Clapton's BB Marshall was wired for 6.6k.
David
TM
- LeftyStrat
TM, thanks for this. Might explain my experiences.ToneMerc wrote: The 6.6K version and low plate voltage can get a bit muddy.
Great rig! Hmm... second favorite! For no visible reason the tone controls really work well on those amps, better than other models... feels like.ToneMerc wrote: I like the JTM50(el34/3,4K version) with the softer voltages in the 415-420V range.
TM
The transitional with a tube rec is really an amazing thing.
I like the GZ34 JTM50 as well. Funny but some of my fav Marshall circuits are the ones that don't sound, "like a Marshall"Reeltarded wrote:Great rig! Hmm... second favorite! For no visible reason the tone controls really work well on those amps, better than other models... feels like.ToneMerc wrote: I like the JTM50(el34/3,4K version) with the softer voltages in the 415-420V range.
TM
TM
Played 4 holers forever wishing for something that I couldn't get until I could do it myself. I do get what you are saying there.
That said, the one in a hundred that *is* the good one really IS good.. something alive in there.. let's poke at it with a stick and see what good comes from that! lol
coupling caps
IF you have TOO much lowend with the 220uf, try lowering the V1 coupling caps instead, it produces a nice sound, my .02Blackburn wrote:Okay cool. I'll go with 8k then. I plan on using a 220uf cathode cap on v1 and don't want an overflow of lows, especially since I play a LP. I'll definately try out the 6.6k just to experiment, but who knows, maybe that's what I'll dig with my LP. I did read that Clapton's BB Marshall was wired for 6.6k.
David
jim
