I found a schematic/layout at Rob robinette's site for this amazing 25 watt design and planning to build it. the layout looks great and should be fun to play since it puts out a little bit low power; so i should be able to crank the amp little more since i live in an apartment. few things i like to ask you for suggestions before i start order the parts for it -
PT OT :
Hammond 1750N - Output Transformer - 3.2K, 4/8/16 OHM, PP, 50W
and
Hammond 290GX - Power Transformer with Primary: 120/220/240VAC 50/60Hz Secondary: 690VCT @ 150mA 6.3VCT @ 5A
will these trannies support 2 el34 configuration as shown in the layout?
does Sozo 500V vs malory 630V make any audible tonal or feel difference ? if so, i will spend the extra on the sozo
also, it has a type 2 master volume which comes handy for a high gain/low vol situation, but I am thinking of a VVR as well. what is your suggestion on this?
*higher resolution layout and schematic link : https://robrobinette.com/images/Guitar/ ... Layout.pdf
Thank you.
