McGohan M20 Amp
Re: McGohan M20 Amp
Any pre PI MV will allow you to crank up the preamp for front end overdrive. Then dial the volume down with the MV.
Re: McGohan M20 Amp
I guess I do not understand how this amp is similar to what you are referencing. This Mcgohan appears to be using the plates from the dual triode to create the phase inversion. How is that similar to the Wizard diagram?didit wrote: ↑Mon Oct 09, 2023 12:49 amYup ..sluckey wrote: ↑Sun Oct 08, 2023 6:56 pmNo. It's just a plain and simple paraphase inverter, exactly like the one at the top of this Wizard page...
http://www.valvewizard.co.uk/paraphase.html
Re: McGohan M20 Amp
Does the 470k just before the PI look like a reasonable spot? Might you have any references from one of your builds for that style MV?
Thanks A
Re: McGohan M20 Amp
The wizard did not draw the first triode. Maybe my note on his drawing will help you see the two schematics are practically identical.
Yes. Just replace that 470K with a 500K-A pot.Does the 470k just before the PI look like a reasonable spot?
Re: McGohan M20 Amp
Hmmm, just tried the MV there and not sure I love it. Seem to be getting blocking distortion... from the preamp section as I try to dial in a nice breakup. This being a PA system, this could be a futile effort.
Thanks Steve for your input.
A
PS yes your drawing was very helpful
A
Re: McGohan M20 Amp
Ok so back to this amp. Just to be clear this schematic is not exactly what I have. The amp has two inputs with 6AU6-A's as the pre-amp stages. I have converted one of the preamp stages (the 6AU6) to triode operation. The screen is to the anode with a 100R, suppressor G to the cathode, and I have a 330k Plate R, 1.5k w/4.7uf on the K. I am managing to get a very useable guitar tone with Treble and Bass controls quite effective. I do have an air-brake on the speaker at 5 (the setting just before bedroom), and I can achieve pretty cool breakup and overdrive tones. I do think that these 6AU6-A tubes are great in triode mode. I have to be careful not to get the guitar to close to the chassis as the tubes are prone to microphonic.
I think I am close to a Clubman configuration.
Anode voltage on Triode change was off, very low. I changed up the Anode resistor to 33k, closer to the clubman (10-18K which seems weird), and changed up dropping string, now have 185v on anode of Triode (6AU6-A), changed up K to 2.2k with the 4.7uf. This has re-arranged the woofy bass to a much tighter feel. I am running the amp with a Big-Shot into the two inputs. One side wet the other dirty, kinda interesting as a parallel amp.
