Eico 666 settings for 6JE6c-6LQ6
Hi.Can any one help me with the proper settings for 6JE6 type tubes ,they are not listed on my chart. I have a 666 tester with 610A adapter. Thank you!
Re: Eico 666 settings for 6JE6c-6LQ6
Try this:
6JE6
FIL: 6.3
GR: 90
PL: 50
LEVERS: 65121 63164
V: 2
S: 1
LEAK: 2-3-7-C
MERIT: C
Hope this helps.
6JE6
FIL: 6.3
GR: 90
PL: 50
LEVERS: 65121 63164
V: 2
S: 1
LEAK: 2-3-7-C
MERIT: C
Hope this helps.
I have this same tester. do you have settings for EL34? There were so many revisions I'm not sure if mine is correct. Thanks in advance.
EICO 666 Tester ( 1-1-78 ) for 6CA7 tube:wawa wrote:I have this same tester. do you have settings for EL34? There were so many revisions I'm not sure if mine is correct. Thanks in advance.
FIL: 6.3
GR: 30
PL: 95
LEVERS: 11435 12111
V: 4
S: 1
LEAK: 3-4-5-8
MERIT: 3
Sorry for the late response!
Simplicity is the ultimate sophistication.
~ Leonardo da Vinci
~ Leonardo da Vinci
