Unusual problem with new build
Im having an issue with my new Gibson GA-100 build. At low volumes the amp sounds perfect. There are no unusual noises hisses pops or squeals. What I do have is a strange charging and discharging effect happening. When you hit a note that would draw some current the amp cuts out instantly then comes back. I checked voltage drop during the phenomenon and there is none to speak of. Any thoughts?
Re: Unusual problem with new build
Measure all the resistances in the power supply dropping string, and check that the power supply caps are properly connected to ground.
Grounds good as are filter caps. I'll check the dropping string again, but I'm pretty sure it is correct.
Another thing to check is that every grid has a dc path to ground.
Grid blocking?
On the schematic it shows the cathodes and one of the grids on the pentode anode drivers connected together. I ran a wire from cathode to grid to cathode to grid to the 470 ohm cathode resistor. Upon looking at the photos of the original amp I cloned the tied the cathode to the grid on each tube and then ran a separate wire to the resistor.Firestorm wrote:Grid blocking?
Could this be the problem?
Here is a link to my build thread it has schematics and such
http://ampgarage.com/forum/viewtopic.ph ... bson+ga100
Measure the voltage of each grid to ground, while the problem is occurring. See if taking this measurement fixes the problem a bit.
Looks like the grid bias in the anode drivers is constantly changing. The schematic shows a value of 1.6vdc I'm getting anywhere between 2.5vdc and -22vdc.
Did you build it with the compressor circuit? If so, does it do it with the compressor switched off?
Dave
Dave
Tube Powered
Yes and yes
That might be it. Is it 2.5v at idle, and -22 when you hit it with signal?jon wrote:Looks like the grid bias in the anode drivers is constantly changing. The schematic shows a value of 1.6vdc I'm getting anywhere between 2.5vdc and -22vdc.
What's connected to those grids?
Can you post the schematic? Which valve(s) is this?
Check the link a few posts up.
schematic
You'd mentioned a large bias shift, where the spec was supposed to be 1.6. Was that on v4/v5?
What happens if you simply remove v4/v5? Does the problem change?
Is there also a large bias shift on the PI - V2/v3? If so, try clipping in another 22m resistor in parallel with the one that's there in the grid leak area of V2/V3. See if that reduces the problem.
