Marshall pre PI MV to Post PI
Hey All,
Is it worthwhile changing the pre P.I. Master Volume on my Marshall 2204 to a Post P.I.? This is a simple change but I was wondering if there would be enough tonal difference to make it worthwhile.
Any thoughts?
Cheers, Mike
Any thoughts?
Cheers, Mike
The Jammy Dodger
Re: Marshall pre PI MV to Post PI
Yes. Much of teh tonal characteristics of a Marshall come from the PI being overdriven.
Do both.
Keep the Pre PI MV and add the Post PI MV.
2203 + LarMar PPIMV. =
It is the current fun to play favorite over at metroamp.
"Rockstah" sets his 2203 up this way, uses plexi era filtering and calls it the "mod 5"
dealer: allparts, weber, antique electronic supply
Man I love the 2204 the way it is.
Are you looking for more bit in the gain with lower overall volume?
As you said it is a simple change, why not just try it out?
yes, do both.
Rockstah Amps: http://www.rockstahamps.com
Rockstah Amps Youtube: http://www.youtube.com/user/RockstahAmps
Builds and modification sound files: http://www.soundclick.com/rockstahplexitweaksandmods
topbrent wrote:Do both.
the thing I did was understand that you need to get the volumes up loud in a cascaded gain stage amp to have it sound good.
While guys were doing one or the other( pre or post master) i did both masters in one amp. of course there is still some tweaking to do after that but thats was what I did.
If your 2203/2204 sounds like this you got it right - http://www.youtube.com/user/RockstahAmp ... 5sco_gLFas
That tone is awesome.rockstah wrote:topbrent wrote:Do both.
HOW DO i change A master volume Marshalls from pre PI master to post PI master. everyone here says its easy ,I dont knkow where the phase invertor tube is - I'm not an Amp builder just on that quest for Tone -, my amp MArshall Jtm 30 ,whats the first thing I do ? does it requier Physically adding another tube /and tube mount or is it just moving tubes around ? Any help appreciated
Ruh-roh...
Please understand that IMO an answer to this question is of no practical relevance at all. - Max
You just move the MV to after the PI.
Rooster1, do you know how to read a schematic, safely discharge capacitors, solder, etc.?
Reading required: http://ampgarage.com/forum/viewtopic.php?t=9023
Wow. Just did this along with the mod5 specs I could find and I think I am done with my plexi mods, for now. This is amazing. Amp sounds really big. Thanks a bunch!topbrent wrote:Do both.
In this diagram... http://metroamp.com/wiki/index.php/Imag ... PPI-MV.jpg
what are the 2.2M resistors for, or better yet what if i don't use them? I ask because i did this type of master before and didn't care for it, but i didn't add those resistors so i'm curious what the do. Looks like they just mod the taper, huh?
NO, those resistors allow there to be a bias voltage if the pot fails.
