I am doing a Trainwreck Express build into a salvaged chassis, and need some advice.
The chassis has a little rust. So I plan to wire brush the rusty spots clean. I thought about spraying the chassis with a fresh hammertone coat afterwards, but then wondered about conductivity for grounding. So what (if any) are the issues here, and what are you recommendations?
Thanks,
Steve
Chassis reconditioning
Re: Chassis reconditioning
Get yourself some of those small round stickers at Office depot or somewhere. Figure out where all your grounds need to be and put a sticker there before painting. Don't forget the pot shafts and jacks. After the paint dries peel the stickers off and you have a good bare metal area to ground to.
Just my 2 cents
Just my 2 cents
Steve, If you have access to a place that does Glass beading, you can usually have it done for about $5-10. That will give you a nice clean finish to start with. Then use Dana's advice and buy the circle sticky's.
Allyn
Allyn
So, what I am taking away from this is that paint will interfere with conductivity, which is why I asked. So, how did Univox do it? The chassis is painted black, inside and out. Special conductive paint?
After painting the chassis you could scrape away ground points like the transformer mounting holes, input and out jacks, etc. I had to deal with this issue with my Express clone because I annodized the chassis. I used a multimeter to confirm connectivity.
Omar
Omar
Tone by misadventure
I guess with the appropriate planning, I can decide where I will want connectivity, and place a stick there, and scrape anywhere that I forget (there shouldn't be many places to begin with if I do this right).
My other question still stands though - the chassis is currently painted black from the factory. Did they use some sort of conductive paint, or are they depending bolts making contact with the raw metal inside the drilled holes?
Just a guess but I would say that they are planning on star washers to dig through the paint and make the ground. I doubt they are using conductive paint as that would be expensive. Just my 2 cents.
