Ultimate Hammond Conversions thread
lord preset
Re: Ultimate Hammond Conversions thread
Post by lord preset »
lord preset wrote:I am just getting ready to start an AO-39 conversion - also 2-el84 and similar voltages but it's a smaller chassis. I'm using this as a guide to do an 18 watt Lite build:
http://home.comcast.net/~seluckey/amps/ ... ammond.htm
The author was able to drop B+ by using a 5Y3 rectifier tube and a beefy power resistor.
Here's what I have so far. This was an odds and ends build using parts on hand with as few exceptions as possible hence the cap board inside vs can caps. This my 1st attempt at PTP wiring -it's interesting to say the least. I followed sluckey's schematic for his AO-39 but added a cut control. I'll go over it tomorrow before firing it up. I'm sure something will be wrong :roll:
billc
just got another one...plus a question
Post by billc »
Just got a L-133 w/ an AO-43-1 amp on a trade, complete with tubes and speakers though they are not in the chassis. Am curious if the original Hammond speakers are any good for guitar, I now have 4 12's and would like to put them to use....will definitely use the grille cloth from the 3 organs I've been given.
[img:1024:768]https://lh6.googleusercontent.com/-u2rM ... 141148.jpg[/img]
Yes the organ speakers are good for guitar most often they are CTS speakers.
billc
Post by billc »
M Fowler wrote:Yes the organ speakers are good for guitar most often they are CTS speakers.
Thanks, that is good to know!...the new ones are Rola's but I have another set from a K-133 also, will check out the codes on them.
BTW, found a Hammond L-100 series manual online that has schematics, etc., might be helpful for some...
http://dl.lojinx.com/analoghell/Hammond ... Manual.pdf
gui_tarzan
Post by gui_tarzan »
donzoid wrote:Funny but so far through this build, I kept telling myself it isn't worth the extra hassle of salvage/rebuild....then I end up picking this up for the cost of gas...
I just picked up an M100 like that a couple of weeks ago. Eleven tubes on the amp... when I get my current project done I'm going to tear into this one.
--Jim
gui_tarzan
Check the speaker ID sites and compare your codes there, mine came with a Jensen Alnico 35/40w 12".
--Jim
donzoid
Post by donzoid »
My L-series has 2 Heppner 12" in it, but I am certainly going to try them since they are alnico.
One thing I have found after looking at (literally) dozens of speaks out of these, is that they never "doped" the edges of their cones for this application (at least I haven't seen it yet). So it's likely if I do like their tone, before they start to occupy half my slant front, they will get a ritual doping.
Billc, I know you can look up the first three numbers on the speaker edge at Weber and they have the code set for most all mfg.'s.
http://www.webervst.com/codes.html
The last three numbers are date of mfg.
https://www.facebook.com/trialbyfirerocks
Be sure your tinfoil hat has a good low impedance ground.
donzoid
Post by donzoid »
Very good Preset! I have been preoccupied for a couple weeks, mostly getting my arse kicked all 'round by the IRS. I am not brave enough yet to try a true point to point - but I like the idea for the future.
billc
Post by billc »
donzoid wrote:My L-series has 2 Heppner 12" in it, but I am certainly going to try them since they are alnico.
Thanks, I did check out the K-133/AO-68 speakers yesterday and they are two 12" Heppners too. Plan to start on the AO-68 first, it is point to point vs. the tag board on the AO-43, looks like an easier job and it works as is. Tentative plan is to go with an Ampeg design on the AO-68 as it has 7591 tubes and maybe a Matchless Spitfire with the AO-43.
donzoid
Post by donzoid »
I considered the Spitfire also for this one....I think the Ceriatone Creme Brulee layout was the same if it helps (I think that was the ef86 pre right?).
donzoid
Post by donzoid »
Looks like I'm stuck now in "diagnostics mode". I tried plumbing in that zener diode I bought (56v/50w) its an NTE5278AK last night, and was surprised to see on my DVM, that the secondary voltage hasn't dropped. At all. I still have 350v dc at B+(1). So this morning I jumpered across it and it appears to be doing "nothing". Same exact readings.
Was I misunderstanding the concept of this to expect about a 290v B+ after installing it? Or is this diode just faulty? It passes the diode check on my meter but I don't necessarily trust that now. I'm sure I got the correct CT wire (not the heaters one).
cbass
Post by cbass »
Its hit and miss some of them sound good some of them sound like hammered dog shit.
I had an alnico rola from a SS organ that sounded great
I have some heppeners that sound terrible
donzoid
Post by donzoid »
Thanks Cbass...a friend has a couple of the Rola's, so I'm going to "aquire" those for a side-by side.
donzoid
Post by donzoid »
OK I think perhaps I just have the wrong CT wire selected for the zener. I'll have to check that out hopefully I can get this sussed out and get this puppy built this weekend.
Edit: after lifting both CT wires and re-testing, it IS the other CT wire that I should tie to the zener.
Doh!
I figured the HT secondaries would have the smaller diameter wire since they only pass mA of current...wrong! Its that big fat red and yellow one.
eniam rognab
Post by eniam rognab »
donzoid wrote:OK I think perhaps I just have the wrong CT wire selected for the zener. I'll have to check that out hopefully I can get this sussed out and get this puppy built this weekend.
Doh!
who gave you that stupid idea? :oops: :oops:
glad you got her figgered out, check yo pms :D
