FET Input
- Funkalicousgroove
Re: FET Input
Use a shorting jack or stereo switching jack, Signal goes in the FET input, then out to the "Shorting" part of the normal input so that when nothing is plugged into the NOR jack the signal is FET by default.
Re: FET Input
The setup I posted in this thread seems to work...
http://maximoaudio.com/forum/viewtopic.php?t=472
