Is a 50v Presence cap too small for 100 watt amp
Guy77
Re: Is a 50v Presence cap too small for 100 watt amp
Post by Guy77 »
jazzbass wrote: Fri Aug 04, 2023 8:52 pm Ciao Franco, the way you describe the effect of that trimmer on the PAB is correct. Regarding the final schematic, yes page 4 is the final schematic.
Cheers
Guy
Ciao Gaetano,
Thanks for the reply, I need some advice, I built a Steel String Special (rootz, a great friend) and was wondering if I could use that lay out an equal chassis and boards and with the proper modifications build the other amp?
Thanks, a hug.
P.S. Can I add you as a "friend"?
Franco
[/quote]
Ciao Franco, yes of course you can add me as a "friend".
Which "other amp" did you want to build?
Cheers
Guy (Gaetano)
jazzbass
Post by jazzbass »
Ciao Guy,
the list of amps I've built is relatively large, various Fender tweed clones in particular 5E3s, all three Trainwrecks, several Dumbles including: ODS Robben Ford from a Ceriatone kit modern eagle, #103, ODS #124, ODR Bluesmaster , ODS 2nd gen, four or five Dumble /TwoRock JM/Wonderland, Steel String Special, Dumblator.....and other Dumble clone amps I can't remember. :P
Please answer my second question: can I use rootz's SSS layout as a basis for building the amp? :?:
P.S. Can you tell me how can I add you as a friend? :D
Thanks, a hug
Franco
franco mezzalira
rootz
Post by rootz »
Hi guys!
I think we got the basics of the Bloomfield drive covered in the schematic that is floating around somewhere over here, right Guy? I don’t think we ever did a layout though.
The SSS is another very cool amp. A friend of mine and me recently sold one to Nalle Colt from Vintage Trouble. He did a big part of his European tour with the amp. Apart from a power tube failure, the amp sings like a bird every night.
Next step I’m going to try is a SSS005 front end and reverb paired with an Odyssey power amp. I suspect (but that is a lot of guessing) that should get me close to an 300SL or later SSS amps.
Franco, which SSS layout are you referring to?
jazzbass
Post by jazzbass »
rootz wrote: Sat Aug 05, 2023 9:40 am Hi guys!
Hi rootz, I'm referring to the schematic you sent me and the relative layout that I put in the attachments.
a hug
Franco
franco mezzalira
rootz
Post by rootz »
Ah that's the Steel String Special. FYI that is a Wonderland with a number of tweaks. Layout and schematics are not exactly the same but both work 100%. There's a lot of places where you can fine tune this design to your taste. Feedback value, tone stack (classic or skyliner, you could even do a Bluesmaster clean), resistive divider after V1b, etc.
Guy77
Post by Guy77 »
That Steel String Special has my favorite feature rootz. The 68K resistor feeding the reverb! I am sure it sounds great!
Hi Franco I am not sure how to add someone as a friend on this forum but you can always private message me here if you like.
Cheers
Guy
jazzbass
Post by jazzbass »
rootz wrote: Sat Aug 05, 2023 11:44 pm Ah that's the Steel String Special. FYI that is a Wonderland with a number of tweaks. Layout and schematics are not exactly the same but both work 100%. There's a lot of places where you can fine tune this design to your taste. Feedback value, tone stack (classic or skyliner, you could even do a Bluesmaster clean), resistive divider after V1b, etc.
ciao rootz,
ha, if I had the knowledge that you certainly have your project could be so many things but......... :lol:
un abbraccio, Franco
franco mezzalira
jazzbass
Post by jazzbass »
Guy77 wrote: Sun Aug 06, 2023 12:55 am That Steel String Special has my favorite feature rootz. The 68K resistor feeding the reverb! I am sure it sounds great!
Cheers
Guy
Ciao Guy77,
I guarantee you it sounds great :D , when I come back from holiday in Greece I want to build a "Bloomfield", I hope the scheme is enough for me.... :roll:
Have any of you tried to build it?
A hug,
A hug, Franco
franco mezzalira
Guy77
Post by Guy77 »
jazzbass wrote: Sun Aug 06, 2023 10:45 am
Cheers
Guy
Ciao Guy77,
A hug,
A hug, Franco
Ciao Franco. I am actually building something similar to it right now. I had to change a few things to make it my own since this is a production amp for me. I have silkscreened chassis and board sets and I can sell you a set if you like. You can send me a private message if you are interested.
Cheers
Guy
jazzbass
Post by jazzbass »
Hi everyone,
some time ago I downloaded PDF about JM OD, I don't remember where or who uploaded it. Can you be helpful in this discussion?
A hug,
Franco
franco mezzalira
Guy77
Post by Guy77 »
jazzbass wrote: Tue Aug 08, 2023 6:51 am Hi everyone,
A hug,
Franco
Hi Franco. I actually like to use the diagram you posted to wire my Rock/Jazz and Mid Boost switch on the amp I previously posted a picture of on this page.
Ciao
Guy
jazzbass
Post by jazzbass »
Ciao Gaetano,
Do you remember who inserted that layout on TAG? maybe he recorded some little demos that would be useful to understand how it sounds.
A hug
Franco
franco mezzalira
Guy77
Post by Guy77 »
jazzbass wrote: Wed Aug 09, 2023 4:20 pm Ciao Gaetano,
A hug
Franco
Ciao Franco. I found the original thread that contained that layout.
https://ampgarage.com/forum/viewtopic.p ... 7&start=15
Cheers
Guy
