Revisit #0183 with 5-piece chassis
ijedouglas
Re: Revisit #0183 with 5-piece chassis
Post by ijedouglas »
Cab I just finished
Ian
Aaron
Post by Aaron »
Wow, great build! Beautiful work!
ijedouglas
Aaron wrote: Sun Nov 19, 2023 9:01 am Wow, great build! Beautiful work!
Thanks Aaron
Ian
gonzomode
Post by gonzomode »
Very impressing build! Possibly you can‘t go further in terms of cloning..
There seem to be an additional grounding point for the loop jacks. What‘s the difference in grounding them at this spot?
Mr. dB
Post by Mr. dB »
Very tidy
ijedouglas
gonzomode wrote: Sun Nov 26, 2023 12:01 am Very impressing build! Possibly you can‘t go further in terms of cloning..
Thank you.
I am not sure of the effect other than it possibly eliminates a ground loop at the EFX send/return. I copied this directly from an original specimen just a few serial numbers earlier than #0183 and based on everything that I can see and match up between that amp and the pics I have of #0183, they are pretty much identical in wiring and layout. Both send/return jacks are isolated and there is a separate ground wire for each running to that ground point
Ian
Reeltarded
Post by Reeltarded »
Dumble lives.
That is MOST impressive!
award70
Post by award70 »
I understand that that's how HAD did it but aren't the fx send/return jacks already grounded via the chassis? I can not understand why an additional ground would do anything except create a ground loop. Maybe the jacks are isolated from the chassis? Not a criticism, just wondering.
Alan
ijedouglas wrote: Tue Nov 28, 2023 4:46 pmI am not sure of the effect other than it possibly eliminates a ground loop at the EFX send/return. I copied this directly from an original specimen just a few serial numbers earlier than #0183 and based on everything that I can see and match up between that amp and the pics I have of #0183, they are pretty much identical in wiring and layout. Both send/return jacks are isolated and there is a separate ground wire for each running to that ground point.
If both jacks are grounded there I don't see how it would break a ground loop or be any different from using standard non-isolated jacks, except it eliminates intermittent/noisy ground issues in a place where there will be a lot of plugging and unplugging going on that might loosen the bushing nuts. Super nice looking build! I'm definitely partial to the traditional eyelet board construction.
ijedouglas
Reeltarded wrote: Tue Nov 28, 2023 5:22 pm Dumble lives.
:D I'm not so sure about that but thank you
Ian
ijedouglas
award70 wrote: Tue Nov 28, 2023 5:24 pm I understand that that's how HAD did it but aren't the fx send/return jacks already grounded via the chassis? I can not understand why an additional ground would do anything except create a ground loop. Maybe the jacks are isolated from the chassis? Not a criticism, just wondering.
Alan
"Both send/return jacks are isolated and there is a separate ground wire for each running to that ground point"
Ian
ijedouglas
martin manning wrote: Tue Nov 28, 2023 5:48 pm
Thanks Martin.
Both jacks are isolated. I'm sure there is a really good reason that HAD went to the trouble of a separate ground lug, isolated jacks and separate ground wires
Ian
Blacksto99
Post by Blacksto99 »
Beautiful work!
I have built several 5-piece chassis, and found that one had a noise problem, so I isolated the jacks and the noise problem was solved. I'm guessing there may be contact resistance between the panel and base plate.
ijedouglas
Blacksto99 wrote: Wed Nov 29, 2023 3:34 am Beautiful work!
Thank you.
That makes more sense that he was grounding it to the baseplate. In the real Dumble he still grounds the speaker jack to the chassis (back panel) as well as the safety ground which I copied in both of the last amps I built. I did tighten those chassis bolts like my life depended on it and checked all ground points between baseplate and panels and there was zero resistance.
Ian
ijedouglas wrote: Wed Nov 29, 2023 4:32 am That makes more sense that he was grounding it to the baseplate. In the real Dumble he still grounds the speaker jack to the chassis (back panel) as well as the safety ground...
That makes a lot of sense, but why not take the same approach for the safety ground and speaker (OT secondary ground)? Maybe HAD's loop and input jack treatments were also a fix for a noise problem?
