my first cabinet build
Koolaide
Post by Koolaide »
butterscotch lacquer with oxblood cloth. Came out OK I think.
pompeiisneaks
Site Admin
Re: my first cabinet build
Post by pompeiisneaks »
Looks nice!
What speaker you putting in it?
pjd3
Post by pjd3 »
Looking pretty nice from here. Your a good inspiration to me. I'm scared to death of idea of making a cabinet!
PJD3
Koolaide
Post by Koolaide »
Got a 12" Eminence Private Jack. Hope to put speaker in and handle on tomorrow to fully finish.
Geeze
Post by Geeze »
Looks good and square! What led you to that size?
Here's a great quote from a acoustic guitar building buddy about wood projects - 'Remember it's wood, if it doesn't turn out you can always burn it and deny it ever existed!'
Koolaide
Post by Koolaide »
couple of things led to size.
-as for actual size measured a blues Jr. and then kind winged it.
-Too old and lazy to cart a bigger cabinet.
-Originally intended to use with an Express I plan to build. (It's on my to do list)
I have never been much on pedals. I have a TS9 and a tec21 GT2. Somehow I got it in my head to do a small pedal board with a mooer baby bomb for power So.... To go with the baby bomb I bought a power supply, a mooer two stones preamp, and the makings for a vemuram jan ray clone. Kinda thinking a small grab and go set up with a bit of flexibility. As soon as the speaker cab is done it is on to the pedal board. Then the Express.
Thanks for lookin.
Bill Moore
Post by Bill Moore »
My first build had a wavy grill cloth pattern that annoyed me, my friend told me to pull the grill, and straighten the lines. I realized that the staples come out just as easy as they go in! Now I spend a lot of time pulling staples, and re tensioning the cloth. (Yeah sometimes after I think it's fine, I'll look at it later, and notice I missed a place!)
alkuz1961
Post by alkuz1961 »
a canvas stretching pliers, used by artists, can be useful for smooth grilling
Koolaide
Post by Koolaide »
grill is pretty tight and straight. but.... I kinda dutched the corners, and the baffle is a wee bit tight. (that's what is causing the bunching you see in the corners. Lessons learned.
Phil_S
Post by Phil_S »
Meh, don't dwell on the mistakes. I've built a few head cabs. On one, I spent time marking which side was the bottom vs. the top so I'd get the seam on the bottom. Well, you have to work fast after applying the adhesive. You see where this is going. When I was done, the tolex was downside up, seam on the top. However, the work was far, far better than I imagined I could do. The seam is hardly noticeable. Still, it belongs on the bottom :oops:
Your work is quite good. No one will be inspecting the corners. Nice job.
echuta13
Post by echuta13 »
Koolaide wrote: Fri Feb 21, 2020 9:55 pm grill is pretty tight and straight. but.... I kinda dutched the corners, and the baffle is a wee bit tight. (that's what is causing the bunching you see in the corners. Lessons learned.
Keep at it! I know I did a couple things wrong on my first, second, and then third cab, but they weren't the same mistakes! :lol: You will definitely get better with time!
If you can't be a good example, then you'll just have to be a horrible warning.
statorvane
Post by statorvane »
Very good looking cab. Grill cloth can be tough, no doubt about it.
