Trainwreck Songbird 30
Starting on my version of the TW Songwriter 30
Drilled and punched holes, made boards, and did some component mounting.
Using Edcor:
PT XPWR064-120 570v 250mA
OT CXPP30-MS-3k8 4/8/16 30w rated
Using Edcor:
Re: Trainwreck Songbird 30
Nice start Mark.
Like the faceplates your using.
Very nice, keep us in the loop...
I don't know the exact values of the silvermica caps used in the preamp to the Clarostat 3M-S bass volume pot but I'm going to take a guess and see how it sounds.
I'll post more pictures as it goes together.
- randalp3000
hope these help
If I get time and can find it I'll pull it apart and measure some stuff for ya.
love the faceplate, looks killer
[IMG768]http://i1233.photobucket.com/albums/ff388/randalp3000/amps/DSCN0364.jpg[/img]
[IMG768]http://i1233.photobucket.com/albums/ff388/randalp3000/amps/DSCN0365.jpg[/img]
[IMG768]http://i1233.photobucket.com/albums/ff388/randalp3000/amps/DSCN0372.jpg[/img]
[IMG768]http://i1233.photobucket.com/albums/ff388/randalp3000/amps/DSCN0373.jpg[/img]
Yes those are nice photos thanks.
Got some more done based on the photo I had.
I need to order a PEC 250k pot as well thought I had one but apparently not.
Stuck a 1m in there to plug hole.
dangit, mark! i've been clean for 2 months now....but seeing your builds always inspires me to get a build going.
looks like really nice work - excited to hear how it turns out and what values you like.
I've had this chassis and parts sitting in a custom head cab by Taylor for probably more then 1 year. So you can see I'm not really blazing away on this project.
I do plan to keep at this one and finish it up soon.
Nice & clean Mark.
The parts count makes this very tempting.
I'll be interested in how it sounds buddy.
Great work.
Great work.
Why Aye Man
Thanks, the 3M-S (linear) pot is the only thing a person has to search for.
Question for my great family of amp builders: I have two old 5M long shaft pots could those be used for 3M if a resistor is used across the pot to lower value? My 3M-S Clarostat is a screw driver adjust pot so I'm going to cut down the threads to get a knob on the shaft.
You can but I think the taper gets screwy. Looks great! I'm interested in one of these too.M Fowler wrote:Thanks, the 3M-S (linear) pot is the only thing a person has to search for.
Songwriter...huh? What's the differnce between this and the others ???
V1 is wired parallel and doesn't use a typical tone stack. Diode rectified and has NFB.Aurora wrote:Songwriter...huh? What's the differnce between this and the others ???
See Hogy's report.
Ordered 250kA PEC pot and found another longer shaft 3ML pot to replace my Clarostat pot. I'll wire up the filaments and power tubes while I wait for parts.
- Turbojunkie
Following this build closely Mark, the descriptions of this model are very enticing!
Looking good my friend!
Adam
Adam
First 25 years of playing, I never got along with EL84's...Now I think, WHAT THE HELL WAS WRONG WITH ME????
