I don't know if I would call it an advantage. This is just my take on it and I am sure that others would disagree. But hey that's what makes the world go round. No matter where you scale an amp you run into the problem of overdriving the scaled part of the amp. If you do just the power section then your preamp is running full blast and you need some way to attenuate the pre from going completely overboard with signal driving your power section. If you scale the PI and power section you get the same thing. So somewhere down the line you need to install a gain/MV/PPIMV etc etc. This involves making 2 adjustment and the extra knob. If you scale the whole amp your guitar volume control becomes that extra knob. The first preamp stage, say V1a has it's bias set by the cathode resistor. It's usually a 820 ohm - 2.7k resistor. That resistor self biases the tube with about 1 - 2 volts by making the cathode more positive than the grid. As you dial down the plate voltage on that tube, your bias becomes less. Looking at your guitar, Your pickups generate somewhere between say 250mv to maybe 1v, if you have some hot ones. So lets just pick 500mv or 1/2 a volt as our guitar's output with the vol control cranked. When the voltage on the grid of the 1st preamp tube drops below that 500mv that out guitar is puttnig out then you start to overdrive the amp. To compensate , just turn down your guitar a little.Guy G wrote:Yeah I've checked it, waiting to build the plexi they mentioned. anyway, why scale the whole amp? any advantages?
Having said all of that , some peope like having the extra knob to fiddle with. The say it gives them extra settings that you don't get by scaling the whole amp. So I guess you need to find what works best for you and go with that.
Mark Abbott would probably have something to say about what address I sent to in Aussey land. Hope this doesn't come a shock to you guys but I don't play guitar. I am a retired Drummer. But don't fret (Pun intended) I have a few guitarst friends and my brother who I loan these things out to, to get their feedback. So I guess to answer your question I would probably sell it after I have spent some time with the amp perfecting the design and wringing out every bit of available tone out of her. I do this as a hobby and for the enjoyment of creating and playing with new things. After I'm done with it , what use would I have for a guitar amp? I only sell about 2 - 3 amps a year. Last year I built 6 and I still own 4. This particular amp was built just to see if I could pull it off and for no other reason than to give me someting to play with.Beerman wrote:Hey Dana. Wanna fit a 240V trannie and send it to me? I'll look after her real good...
But seriously. Has this amp been built to order? Do you think you'll sell it?
Would you be kind enough to post a BOM when you post the schemo and layout?
Love your work, thanks for sharing.
I'll try and do a BOM but I'm not much into doing layouts. Once I get her tweeked in the next week or so I will post the final schematic. Maybe if we can find someone good at doing layouts I would be happy to work with them to get a layout made.
